With Andor 1 player, why does my video file always loop after one minute of playback?
This issue occurs when synchronization mode is turned on, but there are no other media player units to synchronize to. Turn synchronization mode off to resolve the issue.
Thank you so much for this. :pray:t5:
can confirm this works!
I was getting confused as to why the videos marked as long where so short
I don’t think I’ve seen this drop out behavior what kind of video file is being used?
The sync setting is stored on a text file on the USB stick.
@DesertMuseum Sorry for the trouble. If you continue to have problems, I suggest installing the beta software update which defaults to sync being off. Copy the update file to your USB drive and open the menu to install the update:
http://www.andorgallery.com/files/andor1_v1.044.update
@DesertMuseum The menu settings are actually saved to disk when you close the menu. It might be that you didn’t close the menu after changing the setting. I’m looking into addressing this issue in future updates.
