I’m curious about how to get the most from the Solarize function on the Visual Cortex
“inverts all colour values below 0v”
In patching up Expedition and Cadet modules, how could I achieve negative values to utilise the solarize?
Surely a passage would help because of the In & Bias knobs ranging from -5 to +5 but if the output strictly 0 to 1V then I’m wrong.
Have you got @syntonie’s invertor module & can it flip a 0 to 1V signal to 0 to -1V or does it flip it to 1V to OV?
About VU004, it does flip the input signal from 0V-1V to 1V-0V if that makes sense (the signal stays between 0-1V but “content” is inverted).
Then for Visual Cortex solarize part, I’m not sure how is it configured, but for solarization you’ll generally need a bipolar signal (-1V/+1V), then everything negative is rectified to positive, giving a 0-1V signal as a result.
I suppose the VC will scale the 0-1V signal to -1V/1V before the solarize part, so I don’t think you need to scale it beforehand.
(btw VU002 is composed of a 0-1V to -1V/+1V scaler + full wave rectifier)
Cheers @syntonie
I’ve got a couple of each & more in the cart at your online shop
Things are gonna be fun when they’re built & yes, the solarizing mode will simply have to be tested more. I’ve got a simplistic metre bridge module that has at last found a place & reason for being in my setup. Cheers for the inspiration
