I’m wanting to use my Visual Cortex with either PAL or NTSC inputs - keeping my entire system format-agnostic.
Obviously the switch is on the back…
For some reason I had assumed that if I plug in an NTSC signal even though it’s set to PAL, the VC would switch to NTSC. That doesn’t appear to be the case, so no idea where that assumption came from
Would it be feasible to add a breakout switch for the NTSC/PAL setting? Just like the Cadet modules have.
I’m already using the Pre-encoder RGB expander, and would make space on it for this switch.
What’d be ideal, is if the VC’s NTSC/PAL switch just toggles between an open signal and a reference voltage, as per Cadet Sync Gen:
Any chance this is the case? Or would there be another fairly easy to achieve option that doesn’t involve too much hacking of the VC?
but there wasn’t really enough panel/PCB room to fit it in :-\
