NOOB NEEDS HELP: Digital To Analog To Digital
Hi there! I’m new to this video synthesis stuff and could use some help figuring out exactly all that I need to do what I want to do.
I pretty much want to take HD digital files from my computer, convert them to analog to run through RGB effects, and then convert them back to digital, while retaining the quality as best as possible. So that I could edit the effects video into the original without worrying about quality/size changes.
I just need to know what cables and devices are necessary to smoothly do this.
Right now I have hdmi coming out of my computer, if I ran that into a Decimator HX (hdmi in), converted to SDI (SDI out), then used BNC to RCA cables to run into the analog effects, then run that output through a Black Magic analog to SDI converter (RCA in, BNC out) run back through the Decimator (SDI in, HDMI out) back into a capture device would that work?
Any tips and steps in between would be much appreciated. This stuff has been stressing me out!
Happy to be a part of the community, LZX and video synthesis is awesome.
I don’t think there’s such a thing as an “SDI to RGB cable” - it would need to be another converter. Then with standard RGB video you still have to convert it to LZX euro standards (i.e. 0 to 1V and eurorack impedences rather than 75 ohms). So it might be more involved than what you’re suggesting.
Syntonie’s YUV to euro RGB converter (VU003, only available for DIY I believe) might be a good option, if you can find a direct HDMI/DVI-to-YUV downscaler to use with it. You’ll also want something to extract sync from Y, for aligning your LZX gear. I really only know the DIY product ranges so others will have to help out with your options there - Chromagnon maybe? (I use a Cadet I)
However, most analogue modular video gear is going to struggle to retain HD image quality, because it’s not really designed for it - it’s much harder to build analogue circuits that handle the higher data rates that HD uses :frowning:
I meant BNC to RCA, those cables do exist. But it sounds like I’m going to need a converter for both ends. I understand the analog gear is going to have trouble retaining quality, that’s why I want to be able to match it up and edit it with the original file.
What would be the result/downsides of using 2 converters like the BM Intensity shuttle That Desert Museum recommended?
Also I have a Decimator Hx, would there be a problem using that as one of the converters?
Welcome aboard @Kennethfrosty2!
So you should spend a bit of time on this page:
https://www.blackmagicdesign.com/products/miniconverters
Now, that’ll likely freak you out a bit more as there’s like A MILLION converters for all sorts of different jobs. It’s easy to get lost in the weeds comparing and contrasting what the different models do. The two I’d recommend exploring are the:
Mini Converter SDI to Analog - $195
Mini Converter Analog to SDI - $195
These would both enhance your use cases with your MD-HX.
Like others have already mentioned, the Intensity Shuttle is hard to beat for what you want to do in terms of cost and abilities.
So, let me run down what I think you’re trying to do and you can correct me if I’m wrong.
You have HDMI coming out of your computer which you want to convert to analog to run through RGB effects. Lets unpack that a bit. HDMI is a digital signal and likely outputting a 1080p signal.
Now a question. Which LZX device are your trying to get this signal into? I’m guessing NOT Memory Palace due to your interest in getting the signal into analog. I ask because MP can take an HDMI input. <----This last sentence is factual wrong on my end. Correcting here with: MP can OUTPUT HDMI.
If it’s Visual Cortex, it accepts NTSCi @ 720x480i (I’m only addressing NTSC but PAL options exist). So your HDMI 1080p coming out of the computer needs to get to 480i along the way to LZX. This thread has useful details for you:
Additionally, it really matters if you are intending to enter LZX as a composite (single RCA) or component (three RCA YPbPr ). As you repeatedly mention a desire to retain quality through the system, I’d guess you’re opting for component YPbPr input.
If so your HDMI signal needs to be downscaled and converted for entry into LZX. Your MD-HX can downscale the HDMI but cannot convert to component. It can convert to SDI and an SDI to RCA cable could carry composite signal to LZX. But that is grayscale only on one channel. To get the maximum analog image quality the signal needs to be converted to component.
If you choose to use your MD-HX to convert HDMI to SDI, then the next step could be the BMD Mini Converter SDI to Analog. From there your signal would be ready for entry into LZX as YPbPr component.
Early on, a confusing aspect of all of this for me is the fact that SDI is a signal and BNC is a connector type. They are not the same thing though they often work together. Signals work independently of connector types. In LZX the most commonly used connectors for input/output are RCA and S-Video.
So that BMD converter has BNC for all of it’s input/output. Your MD-HX converted the HDMI to SDI and that SDI signal is output on a BNC connector. So the output from the MD-HX is carrying all the signal information it needs to work in YPbPr but needs a converter to do it. You’d enter in as SDI from MD-HX into BMD Mini Converter SDI to Analog, and out from BMD’s three BNC connectors via three BNC/RCA cables into LZX YPbPr in.
A word about BNC/RCA connectors and cables. There’s countless ways to roll these and they all boil down to preference and how much you’re willing to spend. A CHEAP RCA cable can have CHEAP RCA to BNC adapters slapped on any end of the cable. In fact with two adapters you can create a BNC cable from an RCA cable. And vice versa. That said, noise in the system is more noticeable in video, and cheap adapters can introduce noise if they don’t connect firmly. High quality cables and adapters exist, but that is something for another discussion as opinions can get heated when talking about such matters.
Ok. You’ve gotten the signal into the LZX world, you’ve done your processing, and you’re ready to capture back to the computer. Now you need to reverse the steps and account for scaling, converting, and connecting. You can use the same type of tools to do this assuming the computer you have has more than one HDMI port. You’d come out of LZX into Mini Converter Analog to SDI, and BMD SDI out into MD-HX, then MD-HX HDMI out back into the computer.
My Macs do not have more than one HDMI port, so this flow doesn’t work for me. This is why I’ve gone with dual BMD Intensity Thunderbolt Shuttles for my flow. Here are some useful threads on that topic:
Notes on Intensity Shuttles. In my experience with Thunderbolt and Macs they are rock solid. Others have had problems which seem to be experienced when trying to use TB with Windows PCs or when using USB3 Shuttles with Macs. I do not have first hand experience with those issues but have read discussions with frustrated people trying to get things to work.
Pros of Shuttles:
  • HDMI/S-Video/Compopnent/Composite input and output (BUT ONLY ONE DIRECTION AT A TIME!!) So you’d need two for concurrent input/output.
  • Affordable. Even more so second hand because some people get them and rage quit at markdown pricing.
  • All-in-one. You can do what you’re trying to do with two units. The flows described above need at least four units.
  • Supports 10-bit color depth over component output. See this thread for why that might be important to you if highest quality is your primary concern:
Cons of Shuttles:
  • TB cables can be pricy.
  • BMD software (to control input/output settings) can be fiddly to dial in to your exact needs.
  • Not great at upscaling or downscaling. (That’s where your MD-HX really shines!)
Whew! Sorry to go so deep but I know how overwhelmed I was when I got started as there are SO. MANY. MOVING. PARTS!!!
Stay strong, keep digging, and cut yourself a lot of slack as your learning. You might lose a bit of money trying different things out, but usually you can sell and try again without taking much of a loss.
Last words. If you have any friends into this, go try their setups to see what you like and don’t like. I’ve learned SO MUCH over the years through the generosity of others willing to talk shop and showing me their setups. C19 makes that a bit more challenging at the moment.
Good luck and enjoy this part. Its a colossal PITA but you’ll get it and feel like a champ when you do! :slight_smile:
@337is how do I nominate you for poster of the day/week? :slight_smile: This is an awesome, really helpful post.
Cheers @VisibleSignals! :slight_smile:
Thank you so much. I’m gonna let all of this soak in and will keep you all posted on my journey! :metal:
Alright I’m back!
I now have the Decimator MD-HX, BM SDI to Analog 4k, and Analog to SDI converters.
I’ve never used any of this stuff before but I’ve got my HDMI from computer signal going into HDMI IN on decimator. Then I’ve got 1 BNC from SDI Out Decimator going to SDI in BM SDI to Analog converter.
Now at this point i’ve been trying to just go straight to a CRT TV via Single Composite from the Y or NTSC/PAL out, BNC to RCA cable for the BM SDI to Analog 4k converter to test the conversion before I start throwing effects in there.
But all i’m getting is a black screen with a flashing signal.
The decimator is reading my HDMI signal. But i’m not sure if I set my SDI OUT source to HDMI 1 or The Scaler option. When I set it to scaler and do the SD 480i 59.94 option I get the most flashing. But i’m kinda stumped.
So I don’t know if I’m doing something wrong with the decimator or the BM SDI converter. I kinda just opened them out of the box and plugged em in. It’s hard to find information on using these devices for this specific use.
As for the BM SDI to Analog 4k I have zero idea how to configure it. Do I need to hook that badboy up to my computer and do something to it?
I guess I just need help dialing in what I want these converters to do.
Advice and tips much appreciated!
This stuff is a blast but it can drive you loco haha.
Thanks again!
Devices like these need to be set to the right modes, otherwise you’ll get something like this. If you want composite, you’ll need to set the DIP switches on the BMD converter to the right mode. Fortunately, there’s a helpful explanation of the switches on the device itself. More detailed info can be found in the mini converters manual on the BMD site. That manual coveres all their mini converters but its a PDF with an index, so you just scroll down and click on the device you want.
Be sure to select the SD composite mode and the video format (NTSC or PAL) to match your LZX system. Getting that wrong will be another showstopper. There may be other important modes to set.
I can’t help you with the Decimator device, but I expect it has something similar.
I noticed you mentioned ‘Memory Palace can take an HDMI input.’ Could you explain further? Thanks!
Thanks for the reply!
I looked in the manual and found the switches. I turned switches 1, 5, 7, 8 off. I think those were the right ones it said to turn off for Composite, but now it’s just flashing a little more.
:joy:
Anybody with BMD SDI to Analog 4K converter know the right switch sequence to just get composite?
Idk if there’s anything I need to change via software.
I haven’t downloaded the converter utility software hopefully it’ll run in my Mac :grimacing:
And If anybody else knows there way around a decimator md hx,
I tested the Decimator HDMI In to HDMI out correctly just out of curiosity and it worked so that was good, but i need to convert to SDI for composite conversion. as far as the SDI out, I’ve got my scaler set to SD 480i 59.94, with that as my source for SDI out, going into the BM SDI to Analog 4K.
So settings are:
Input status
H: 3GA 1080p60
D: 480i 59.94
Control
SDI OUT SOURCE
Scaler
If I set my SDI out source to HDMI 1 it’s blank, if I set it to the scaler it’s flashing.
:tired_face::heart:
Hey @brendanleespengler. Take a peek at this:
And specifically this section:
  • DVI-D Output . Uncompressed digital video output in RGB 8:8:8 colorspace. You can use the included DVI-D to HDMI adapter if HDMI connection is needed, or a DVI-D to HDMI cable. Currently supported are weave interlaced 480p60 (while in NTSC/480i mode) and 576p50 (while in PAL/576i mode.) Output resolution and deinterlacing options will be expanded in future updates.
Let me know if you have further questions on it and I’ll try to lend a hand.
@Kennethfrosty2 keep plugging away and hopefully something will budge positively for you. The dip switches on the BMD gear need to be precise, as do the settings on the MD-HX. I might have a chance to break mine out this weekend to try and determine settings to share with you. The one complication may be my BMD converters are not 4K so I’m not sure the device settings will be the same.
Hang in there. We’ll get you sorted!
Thanks so much! Have a good weekend I’ll let y’all know if I figure something out!
:metal:
To be clear, the MemPal outputs HDMI, It doesn’t take an HDMI input as you stated. A typo, maybe?
Ah! Yes. Output. Not input. Thanks for clarifying for the record. Sorry for the confusion. I’ve edited my original post. :slight_smile:
Checking the manual, I see that this BMD converter doesn’t do format conversion (NTSC<->PAL), but it does do scaling. So, switch 5 must be set to on for composite and switch 1 must be on to enable processing (scaling). This will give you SD composite output from socket 1.
Then it gets more complicated - you can cycle thru the different conversion modes by toggling switch 1. I know this is a pain to do, having done this myself with the non-4K version of this converter, but its worth doing to get the right mode. I use a very small bladed screwdriver to set the DIP switches.
After you get this done, you should look at the other switches for any other options you may want. Switch 7 is important as this sets the voltage level for black. So, if you want black to be actually be black, this must be set correctly.
I gave it another bout and still nothing, I’m not even gettin flashy flashy anymore.
I’m toggling they switches seems to not really do anything.
I’ll keep tryin!
Do you have a monitor with an HDMI input? Can you connect it to the HDMI output from the Decimator? If you can get a good signal from that, you’ll know the problem is with the mini converter. If not, you know there’s a problem with the Decimator.
Yeah I’m pretty sure the decimator is running fine, I’m able to use it with some cheapy HDMI converters.
I think it’s the BMD converter
