Unfortunately the only thing to do with Diver quirks at this point is to wait for the new firmware. TBC2 has commanded full attention (away from Memory Palace and Diver), but the good news is that all progress on TBC2 will benefit its Orion siblings (and Chromagnon).
Iāve been running some tests with using the diver to sync a prismatic ray via passage and it seems like the 1 pixel seam is causing the sync issues. They can appear almost identical! I wouldnāt be surprised that once the 1 pixel seam issue is fixed, the sync issue is also fixed. Itās frustrating to sync the diver at the moment. Fingers crossed this gets addressed!
Weāve pulled Diver out recently in prep for a bugfix release. So hopefully you wonāt have to wait much longer on that update. This issue (the phase texture seamās starting position) is the first one to correct.
It does seem to relate to sync alignment/offset. But which issue is causing the other, itās hard to say. I will have to look at the sync pulses together on the scope (possibly after tapping some wires off testpads on the PCB) in order to diagnose it with certainty. It could just be a glitch in my code for the phase wrapping.
For the XY measurement, if you adjust the phase slider, can you move the line to the left side of the raster?
Can we see a screenshot of the glitch youāre seeing with the Prismatic Ray?
Not trying to give you busy work; but if you want to keep seeking I wonāt stop you! Iāll solve this when I get into it.
Hereās an example of the sync glitch with Prismatic Ray. You can see the blip every few seconds. Itās kind of a messy patch and running through some structure fx but itās hard not to see the jump when it happens. Streamable link to Untitled 05
Any Updates on that topic?
Iāll post here on the forum as soon as there are updates on Diver. Iāll be digging into it after the TBC2 release, which is what Iām working on now.
While doing a full system/module reorganization, I got my Diver to work this past week for the first time ever!
My specific issue was having some of the following RCA female-to-female couplers in my sync chain.
I donāt believe the coupler failed as the sync chain worked fine with for analog modules when these couples were present ā but these couplers caused issues for Diver (and maybe MemPal too but Iād have to go back and check). The couplers worked fine with video signals in general.
