Luma processing is fun in and of itself, but I would like the option of passing full color through composite. My composite input options ATM are Vidiot and Visual Cortex, and both only input greyscale.
I think the TBC2 will do this, or at least convert color composite to 1v RGB, which will work as well for what I have in mind.
In the interim, has anyone used this convertor? It’s a tad expensive for what it is, but if it works OK, it might be worth it.
Yes, I also use one of these devices, and used it with a V-4 and a VC. It’s simple, effective and reasonably priced. I often forget its there, it works so well!
This converter from Ambery (which looks identical, and is the same price) used to be listed as the recommended component-composite converter on the old LZX site. I’ve got one, works great.
