Announcing the fifth Orion module, Fortress
We weren’t sure if we would be able to sneak Fortress into the initial set of Orion releases, but the design has matured quite nicely. We’re happy to welcome @pbalj onto the Orion development team on this one!
https://www.lzxindustries.net//shop/product/lzxoft-fortress-3046
Dammmmmmnnnnn! Orion is on some next level ish!
Would i be able to use the fortress by itself with a Vidiot? or would i need a cadet sync / visual cortex
You will need sync, but you could sync from the Vidiot’s sync output. You’ll just need to pass the RCA cable to the rear of the Fortress module.
Thanks a lot Lars!
I just found this thread, perhaps you could add fortress to the list of modules that require sync :slight_smile:
