This project is about “upgrading” the Cadet VCO with more waveforms.
However, this will be done with Lunetta style Shift Registers, Counters and R2R ladders,
so the waveshapes are stepped. With filter switches these can be somewhat “smoothed”
The idea is to have alternative Horizontal waveshapes to use for modulating Vertical VCOs
Are you planning to have multiple simultaneous shaped outputs per input? Or is it going to be just one output that can be set to shape a variety of ways?
Oh wow, looks like something I’d see from an Ian Fritz circuit (ie, Wavolver)
last night I had fever dreams about a vide-rate tri to sine converter…
I think this came about because when I struggle to sleep I try and “meditate” by picturing a perfectly clean circle in my head - it’s hard enough that I fall asleep doing so (and hard in video synths too!)
Depending on how you’re dividing, your IC may have a reset pin at your disposal. Are you using a flip flop?
EDIT:
I zoomed in to your photo above. Is that a CD4040? What are you doing with the reset pin and what are you clocking it with?
The Cadet I guide shows that the 14-pin connector uses 5V signals while the front 3.5mm jacks and 16-pin bus are both 1V. You may want to use the 14-pin connector’s signals through a 74hc14 either once or twice depending on what polarity the signals need to be for the CD40xx.
I would also like to suggest a three-way switch that syncs the reset pin to H-sync, V-sync or none for scrolling.
