Vidiot + '?' - Next Module?
Just asking for suggestions, but if you were starting out with the Vidiot …
what would be your next choice for a LZX module?
*thanks in advance.
staircase, pendulum, arch are my favorites that don’t require sync and are on the cheaper side
if you end up getting a couple of those and are still enjoying video synthesis
start considering what kind of things you want to make
that should inform your module purchases
I really appreciate the speedy response here, and from everyone that has replied to my various posts. Good advice. I’ve been interested in video synthesis for quite a while, but have just recently decided to dip my toes in the water. Got a Vidiot on order, so am looking around for ways to supplement it. Thanks!
in these two videos the vidiot is getting combined with the larger system
there are more of these kind of videos on my account there
the vidiot is a great starting point but has gotten so much more integral now that I finally got it setup like I want
sync coming out of the vessel case into the composite in on the vidiot then I can use visual cortex as the “sync master” and just patch in and out of the vidiot with RCA or 1/8 outputs
I’ve recently grabbed my Vidiot and begun to really put some time in with it again. CURTAIN! My current recommendation is Pendulum + Curtain. Curtain can really add some subtleties and depth, especially when patched into the LumaProc CVs…
any of the DIY lzx modules you would recommend for adding to the vidiot?
the closest to DIY modules that I have are the sandin IP function generator and differentiator
function generator in combination with the luma processor of the vidiot is just golden
the differentiator is good fun too but I haven’t used it specifically with the vidiot just yet I don’t think
This video series might not make the choice any easier. Vidiot plus ANYTHING is pretty fun.
vidiot + fader if you have some external audio eurorack modules.
It will allow you to have more control on your vidiot.
Vidiot + curtain is my favorite pick. Then the pendulum, and then the staircase.
Hey there, I picked up a bridge after I got a vidiot so it could talk to my circuit bent video mixers but I’m real curious as to what direction you decided to branch out in. I seem to be in a similar location and want to build upon the video synthesis aspects of my videos. I was looking at Pendulum or Staircase but I haven’t been able to decide.
For me it was the diver module,after that i’ve added a curtain and that’s it so far.
