Hi wednesdayayay, thanks so much for the reply …
I tried your advice: I’ve tried different sources, and different monitors, and I’ve tried from the Luma output, and I’ve tested every knob and switch and possible combination I can think of, but I get the same results …
Here’s a “Part 2” of my situation - https://www.youtube.com/watch?v=yPlZH3gFiWQ
Same results. I’ve tried patching every witch-way and playing with all knobs and switches, but nothing ever changes.
Also, maybe this is a dumb question but …
If I remove my source all-together, I just get a black screen: Nothing. No matter how many combinations of knobs and switches, it will be a black screen.
Here’s a quick “Part 3” that shows what I mean - https://www.youtube.com/watch?v=8LcTBHYMZtQ
It seems it could be a similar problem that this user had - Vidiot - Troubleshooting
In that case, the recommendation is to take the Vidiot apart and Twist the Ribbon Cable - https://www.youtube.com/watch?v=qpiPMf4VLQE
So, my questions are …
- Is the behavior you see, from my video test, is that normal?
- If it is normal, is it just matter of patching things in order to get it working?
- If I use NO SOURCE, is it normal to just have a black screen there? Or does Vidiot generate visuals even without a source?
Thanks again for your help!
