Vidiot & Cadet sync
Jonas’ method will work! But Vidiot also contains a dedicated sync output jack. This jack loops the input sync thru to it if the loopthru switch is ON. But if the loopthru is set to OFF, it outputs Vidiot’s native composite sync.
So either…
  1. Vidiot Sync (or Composite or Luma) Out to Cadet 1 Sync In
  2. Cadet 2 Video Out to Vidiot Sync/Luma In
Option #1 (Vidiot sync to Cadet sync) uses the dedicated sync connections and allows you to easily slave the entire rig to another source (via Vidiot’s sync/luma input) easily. In this rig, Vidiot replaces the need for Cadet 2 and Cadet 3, which is nice.
