Hey There.
I have a vidiot and a semisize cadet+Castle system (33 modules so far).
With 3 cadet III, and 3 Cadet II in the system, it already makes the syncronization of ins and out a rather complex task. But i manage using TBCs and referenced sources from my hackingtosh via lots of black magic and a genlocked scanconverter etc…
But in order to get the vidiot to play along in sync with the system without having an active video input showing, I for now use an old Syncronicing pulse generator that i had on a shelf for years, for making a Black Burst ie a synchronized signal that have no image that i can input to the vidiot. (Plan is to setup a small 2 input one output switch with the blackburst on one, and whatever source i want to put into the vidiot on the other.)
But i would rather not have to carry the sync generator along for gigs, and have wondered if there is a Black Burst already generated somewhere int the system that could be used…
Recently i followed the sync busboard design thread, and learned that there indeed is something on pin 7 of the 14 pin sync header bus, mentioned as burst in that schematic thread. But there is also a composite sync, as far as i can see. In the owners manual of the Cadet I the pin 7 output is labeled Burst Gate.
So my question here is, is the burst gate the same signal type as the black burst that my rackmount synchronizing pulse generator sends out, or something different?
And from the same part of the soup in my head: what is then composite sync, if not blackburst?
If long technical precisions is not on the to do list for now, then please just tell me if its possible, and what pins I should connect to generate a black sync signal for my vidiot?
Best Lau!
