Scriptable Video Module
Exactly! Just to illustrate my point, TBC2 is an ~$800 module that’s an integrated dual input/upscaler/downscaler. That sets the cost of an external video source at ~$400 per input, if you want to expand your system in a modular way (multiple shader units.)
So the first shader unit may only cost $100 (pi based DIY project or whatever, including all the parts and padding it a little.) But the second one costs you $500 (presuming you need to purchase the input infrastructure, whether that’s TBC2 or another solution.)
So, for the sake of illustration, if you wanted 5x shader modules in system, if you need external input modules that costs you $2100 (2x TBC2 + 5x shader units).
But if you could find a way to sync the video output of the Pi, that cost drops from $2100 to $500!
So sync’ing the Pi would be like finding a goldmine in terms of your system budget! That’s the point I’m trying to make.
the raspberry pi zero2 w came in today.
now I’ll have to get some other stuff (5v adaper, SD card etc) to get started.
Looking at the recurBoy github again.
I’d like to make something like that but with less features (no sampler or FX)
and no menus would be my focus,
to have a couple of selectable noise gradients (like those in Touchdesigner) with cv control in a module or standalone tool.
Curious if you would make this open source so people can develop their own modes?
I don’t see why not, as all my products are opensource
note that I consider myself a beginner :slight_smile:
One place to start could be openFrameworks. I’ve made many projects with it and some on RPIS and it’s an ok environment to work on. :slight_smile:
Inspired LoFi Future’s //SimpleViz (and while waiting for it to arrive) I tried the Arduino as scriptable module, here’s a how to. The TVout library is quite basic but compared to a RPi it’s a lot easier to set up a plug & play module that can be controlled with buttons and/or sensors.
Can you cover the whole screen?
I always get black bars around the image.
No I’m also not able to fill the whole screen. The script in the picture was supposed to plot lines from 0 to max width and height. Maybe some kind of sync issue?
The micro is not fast enough I guess. Although they can generate sync good enough, like in the cadet, but having a while frame in memory and being able to spit it out on time is another question.
btw, Erik has put his Slimshader module on GitHub and the Pi image on his site here, and it is a quite well-developed project to do what is being described here:
http://www.erikoostveen.co.uk/Slimshader.html
could you not just clock against a sync signal via gpio?
Admittedly just realising this is pi zero and not Pico, where you probably don’t have as much cycle level control over rendering output timings.
Yeah, Pi Zero can’t have its video synced to an external signal, as far as anyone knows. There may yet be an undocumented way, but no one’s found it so far. It’s kind of doubtful there’s even an undocumented way, though.
there are always ways.
Well you could, but my guess is it’s quite jittery. Video genlock always involves specialty PLL circuits, often using VCXOs. The new RP2040 with it’s PIO blocks is a better candidate. IIRC, the main issue here with the Pi is lack of documentation from Broadcom. SD video is going to tolerate jitter a lot better than HD will.
I suppose I should plug the project that finally took this idea to the finish line, for me! It is a hybrid system using RP2040 MCU + Lattice ICE40HX4K FPGA. In this case, the pixel clock comes from the input video peripheral IC itself, which drives the logic and then the output.
will there ever be a eurorack videomancer?
I don’t think so – the interface is designed for desktop usage. Will there ever be a EuroRack FPGA-based effects loader compatible with Videomancer programs though? Definitely!
