I would prefer a “boxes and wires” GUI, because I’m used to that type of programming.
That would make it usable for a larger group of users too. I really like the axoloti / patchblock software!
Would this module spit out analog video?
Digital effects would be cool!
I dont know if will have digital effects… it will be probably to generate rasters (or vectorgraphics) I really dont know.
I totally understand your appeal to boxes-and-wires.
I honestly love how the shbobo shnth handles this
you can write your code in a text editor if you want and it works perfectly
you can also use the app and program with nesting modules which I find easier than boxes and wires
as someone who has only ever programmed for fun I much prefer boxes and wires to text
this is a module I’ve wanted for a long time
wouldn’t the [http://erogenous-tones.com/modules/structure/](http://erogenous tones structure module) cover some of this territory?
and I’m not really familiar at all but the https://www.critterandguitari.com/products/etc seems like a standalone version although it is python based
Thanks for opening this discussion! Mainly I want to be a spectator at this point, and just get my finger on the pulse of what you all want or are imagining.
My thought is more of a devboard (like Raspberry Pi or Arduino), but with perhaps a module version, of what is currently the Memory Palace/TBC2 platform. There are several devboards out there with video in and out, but it is pretty much always HDMI only and the boards with more than a single input are few. What I think we could offer is the devboard with at least two external video input channels and an output that runs synchronous to the inputs. This means you have proper analog genlocked I/O, and the device can then be modular and expandable. We would put into place all the basic infrastructure in the FPGA for time base correction/frame sync, frame buffering, and all the drivers. So it would effectively be a user scriptable video mixer/effects processor. Add MIDI controller and code to make pretty much whatever dedicated machine you wanted.
TBH its fine ifs its a standalone, that means the board can be bigger if needed by design, and I can save some hp on my briefcase, and bring the board to gigs if I want.
The primary things I’m interested in knowing right now are: What are the use cases for you? What problems does this solve? What can you do with this that you can’t do with existing gear? How far is your imagination taking you when considering a scriptable environment?
We haven’t made the decision yet, but we may also open source the software portion of the Orion modules (the VHDL/FPGA portion would be fixed.) This would make each module in the series a reprogrammable video DSP focused on whatever video processing is going on in the FPGA core (in the case of Memory Palace, for example, there is a hardware accelerated texture-mapping unit, colorspace converter, chroma/luma keyer and alpha compositor.)
All of this stuff requires, at the least, clean code and documentation on our part. So we need to get through our first release cycles and let the firmware mature first. After that though, we may have a really great platform to springboard off of.
Check out the Pynq board… it’s a Python scriptable environment for Zynq (the architecture we’re using.) One option Ed’s brought up is to fork the Pynq platform and then implement device drivers for it for our various FPGA/DSP cores. That would provide a good basis for further extension.
Another selling point of a devboard is that it could be used as an OEM base for other people’s video synth/video mixer products – the same way we use the Raspberry Pi for our Andor 1 media player.
I’m reading on it and I’m already in love with the idea, seems like a very powerfull and dev-friendly platform.
The idea to embedd a jupyter notebook on the A9 cortex (linux) its very amazing.
Regarding what are the use cases I can think of:
  1. Machine Vision (Artificial Vision and Machine Learning) for tracking objects from the input video, and provide that information as analog signals to the modular, or to stick an tracking point or object into that position in the video, in real time!.
  2. Video Effects, to write filters like in ffmpeg (like this or this videos I made) or like https://deepart.io/video/, but again like in real time.
  3. Complex/Dynamic Key Generators, for video mappings but in real time?
So some of this can be done on computers but in batch process (non-real time). Most of this falls in the research areas of Computer Vision / Computer Science and its not very artsy. Or maybe it is! :slight_smile:
Here are some examples of video effects that are scripted thru filters in ffmpeg its very interesting http://oioiiooixiii.blogspot.com/search/label/FFmpeg
I work a lot with Touch Designer, Quartz Composer and Isadora so my dream module would be something that includes a visual programming language. That would make it much more accessible to people form a non programming background.
Hello
My point of view
What i like about eurorack is their simplicity / ergonomy : one module / one function and patch cable.
The best scriptable module i know is a laptop. If i miss a module it s something like Expert sleepers ES8 ( cv《》usb) with video rate frequency ability, to interface lzx with say pure data or jitter…
thx
I agree with you partially, but there are stuff that its too complex to write for a GPU or it will work too slow on a CPU, so having a FPGA on board is a completely different thing. Because its basically reprogramable hardware, so you can change the hardware (make the physical logial gates change) based on your source code (known as VHL), this is super powerfull for highly concurrent and real time applications that, as I said before, can be solved in a Laptop but in a batch process, not in real time.
right. i inderstand.
But what i m doing with jitter is enough for me , real time and an interfacing module would be great
as for me, I’d like a video effects unit that can do the things a Korg Entrancer can do, but then in full PAL format.
It would be great to be able to edit weird digital functions and then use them on analog video.
and automation come to mind.
(I’m an HPC / Scientific R&D person IRL.)
I’m happy to do anything up to and including writing code in Vivado (but I suppose that depends on the licensing…). I don’t care so much for visual programming for something like this, personally, but I understand the appeal as it is a natural analogue for patching. I would worry about the cycles eaten up by a framework that made things easier. I enjoy hybrid programming models - and I think the Zynq type parts are really exciting in that way.
The part of a video processing module that I would find the most daunting (and thus the greatest value add) is all of the integration and testing of the peripherals (jacks and thus ADCs, encoders, display, etc.) that are connected to the SoM.
That’s definitely the value add from our perspective too. There aren’t any existing Zynq or FPGA+MCU boards out there that provide extensive interfacing to analog video encoder/decoder peripherals, so that makes it hard to tinker.
While a visual programming language would be awesome, and it may even be possible to port existing ones to run on this board, we’re thinking more at the primitive level of just the platform with core drivers – so any visual programming language would probably be another layer on top of that, and on the user application side. Maybe there’s an OEM/devboard that’s more barebones and a visual scripting/reprogrammable interface module is something else in the Orion Series lineup. All the “Orion Class III” modules (currently TBC2 and Memory Palace) use the core architecture of Zynq SoM + loads of video related hardware peripherals.
I’d be pretty excited about any kind of devboard version of the MP/TBC2!
Pretty agnostic on language but I’d hope there would be both a high level and a low level way to engage with it. I have a C&G ETC and while I think they did a great job with that platform, PyGame doesn’t cover everything I want to do with a programmable system. I’d be interested in doing more demoscene-style low-level programming, ideally with a mix of CPU and GPU, 3D geometry, etc. I’ve also been daydreaming lately about a FPGA RNN/GAN implementation, so you could train models on a PC and then apply them with low latency in hardware.
My #1 request, though, would probably be a video module with a long sample buffer (whether an official Orion module or the devboard) that can participate in the monome i2c serial messaging system (teletype/ansible/mannequins/ER-301/Matrixarchate/etc.) I’d be most interested in some ways of scripting loop points on a sampler to recreate Raphael Montanez Ortiz style chopping & sliding buffer effects.
For me the most interesting point right now would be a Perlin/Simplex noise generator. It is an essential part of my digital work (instagram.com/vantaslog) and would love to see how a staircase performs as an fbm. Lars asked me about this idea long ago and I’ll be happy to either take the challenge on developing it myself or helping others in the task.
A second point will be to gather in one module few of the effects present in devices like the roland entrancer. Flip-flop, slit-scan, pixelate, etc. In the direction of what Memory Palace would be able to do but in a smaller factor.
I’d like to see something that reacts to the video input and gives correlated CV/video outputs
so we could say get a static (if the picture is static) CV amount correlated to the amount of Green in the picture
building patches that react to the video output is something I’m interested in
I’m going to continue thinking of other things and re read this thread but I really enjoy the idea of programming some video synth tools
@wednesdayayay Great thoughts – I have a lot of ideas like this for image analysis across multiple frames (longer temporal constant.) Another constant CV value it would be nice to have is angle of movement, amount of motion across the frame, etc.
this in real-time :heart_eyes::heart_eyes:
a system like the ffmpeg filters that can be cascaded/chained/routed would be awesome
angle of movement sounds rad too
this is maybe a little off topic maybe not
paint by numbers
I was recently painting a backdrop for our production of winnie the pooh
the way we typically do this is project onto the flats trace then some shading then paint over it in whatever the desired style is
what I would like to do simply is
chroma key out several major colors (maybe just RGB since we tend to only buy RG&B plaint and mix ourselves anyway)
under each color would be an oscillator (static image is just fine)
maybe Red would be full horizontal Green would be between horizontal and vertical and Blue would be vertical
this seems doable in a system with 3 oscillators, 3 polar fringes, 3 doorways and a visual cortex
is this too ridiculous of a use case?
scrolling bang
with the additional scrolling options that diver and memory palace open up perhaps it would be interesting to derive triggers/gates/bangs/go messages for scripting from a settable threshold for NESW faces around the outside of the viewing screen and allowing these triggers etc. to be assigned wherever
this could really open up some self playing/wiping
picture in picture
picture in picture being a bit easier would be very nice but would require more than one RGB path on the module, multiple modules or a 3 channel grayscale PIP workflow which would still be fun and elevating I feel.
thinking back i seem to remember the sampler module being talked about as a video collage module so maybe some similar territory is covered
color pick and switch
something like the polar fringe chroma keying where in addition to picking the color you want to pluck out or around you also pick the color that goes in there instead
“typing this out loud” made me realize that polar fringe and color chords would cover this but it would be neat to have it as a simple programmable & reusable module so we can that could be stacked for a larger re-colorization patch
Quadrants
perhaps even something where you could assign quadrants of the screen ( I seem to remember someone mentioning this a while back and I’ve got some of my own experiments going that I haven’t written about yet in this territory) tasks
if we could write conditional statements based on the location (within the quadrant) of a color blob meeting a specific requirement for size and color that would be pretty neat
