Hey fox, do you have a pcb panel set available?
Sure do. I’ll PM you.
Hi Fox I just requested a veil pcb set, can I have a shutter pcb set too please thanks
I’ve got v3.5F of the PCBs rather than the v3.3F shown in the build guide. V3.5F has a few holes that the v3.3F does not, Is there a v3.5F diagram for the optional section showing where the diodes should be soldered? Thanks
In v3.5F the optional diodes have been made mandatory and are now located on the frontside of the board. Follow the silkscreen and the module is complete.
That makes things easier. Thanks for the quick reply!
Just a heads up, the BOM at the top of the page is inaccurate, at least for the V3.4F boards I received. Most important is that the BOM calls for 6 1N5711 diodes, while the boards need 12. Also calls for 23 499R resistors, I only found spaces for about half that many.
Luckily I had enough parts in stock but just hoping to save someone else an extra Mouser order.
You’re right, @Whelm.
The post is no longer editable so the above will forever be missing the rev info (v3.3F FYI).
Here are the BOMs for the other two revisions. v3.5F is the current and/or final revision.
BOM for SHUTTER v3.4F
| Qty | Value | Parts |
| 1 | 330n | C1 |
| 5 | 10u/25v | C2, C6, C23, C24, C26 |
| 18 | 100n | C3, C4, C5, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21 |
| 12 | 1N5711 | D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12 |
| 2 | 1N4001 | D13, D14 |
| 2 | 68R | FB1, FB2 |
| 1 | CD4053 | IC1 |
| 6 | LM6172 | IC2, IC3, IC4, IC5, IC6, IC8 |
| 1 | TL072 | IC7 |
| 13 | PJ302M | J1 – J8, J10 – J14 |
| 1 | 10-PIN_PWR2 | J9 |
| 11 | 100K | R1, R2, R3, R4, R5, R6, R30, R31, R32, R48, R51 |
| 18 | 1K | R13, R14, R15, R16, R17, R18, R33, R34, R35, R36, R37, R38, R39, R40, R41, R42, R43, R44 |
| 1 | 20K | R28 |
| 1 | 4.99K | R29 |
| 14 | 499R | R7, R8, R9, R10, R11, R12, R19, R20, R21, R45, R46, R47, R49, R50 |
| 1 | 7805 | U3 |
| 1 | B100K | VR1 |
| 1 | PCB/Panel Set | - |
| 1 | 10-16 Pin power ribbon | - |
| 13 | 3.5mm jack nuts | - |
| 1 | Transparent Davies knob | - |
| 1 | 6-pin stackable header | - |
| 1 | 8-pin stackable header | - |
| 1 | single row, male 40-pin header | - |
BOM for SHUTTER v3.5F
| 1 | 7805 | U3 |
| 1 | 10-Pin Header Box | J9 |
| 15 | 1K | R13, R14, R15, R16, R17, R18, R36, R37, R38, R39, R40, R41, R42, R43, R44 |
| 1 | 20K | R28 |
| 1 | 330n | C1 |
| 1 | 4.99K | R29 |
| 17 | 499R | R7, R8, R9, R10, R11, R12, R19, R20, R21, R33, R34, R35, R45, R46, R47, R49, R50 |
| 1 | B100K | VR1 |
| 1 | CD4053 | IC1 |
| 1 | TL072 | IC7 |
Now that you have a bunch of modules out, may be time to start compiling some of that info somewhere like Github, where versioning can be more easily updated?
(Or maybe a mod here can just help with the edit in the above post?)
Definitely. I’ve been working on a website too, so it will be nice to have all of the scattered info centralized. And yeah, Github is part of that transition.
Looking forward to it. Keep up the good work!
hi! are pcbs available at the moment?
