My first official order thread!
To fund the next (and hopefully final) revision of my RGB Switcher, I made two different Buffered Multiples. I only have 17 of each of these for sale. I will likely have more made at a later date.
Description:
- Module (A) - Dual 1:3 Distro Amp
– 3U, 4HP, 40.64mm (1.6in) deep
– 2pcs: 1xFaceplate, 1xPCB - Module (B) - Triple YRGB Distro Amp
– 3U, 8HP, 40.64mm (1.6in) deep
– 3pcs: 1xFaceplte, 2xPCB
Both modules are of course video-rate multiples and with cascaded inputs, each module can be used in several ways. the Dual 1:3 mult may be used as a Single 1:6 mult and the YRGB mult may be used as a 1:12 mult, Dual 1:6, 1:9 & 1:3, and more!
These would be great companions for the upcoming RGB switcher which will now have a switched VC input for the threshold pot. While these are labelled for YRGB, consider using the “Y” for several daisy-chained RGB switchers.
Available Options:
- Module (A) DIY PCB - 1:3 Distribution Amplifier - $16
- Module (B) DIY PCB - Triple YRGB Distro Amp - $19
- Module (A) Built/Tested - 1:3 Distribution Amplifier - $74 (2 available)
- Module (B) Built/Tested - Triple YRGB Distro Amp - $80 (5 available)
Shipping:
- First Class to lower 48 states - $4
- UK/Germany (1-2 modules) $14.50
- Other Accommodations - please ask
I’ll combine shipping for anyone who wants more than one. Reply below, or PM me to get yours!
Below you will find the BOM and photo build guides.
Thanks everyone!
-Fox
List:
- 337is: 2x Each - Shipped
- rempesm: 1x Each - Shipped
- meudiademorte: 1x Each - Shipped
- dr_how: 1x Module (B) - Shipped
- Robertunist: 6x Module (A), 4x Module (B) - contacted
- brdaniel: 2x Each - contacted
- wide_closed: 1x Each - Shipped
- Jestern: 3x Module (A) - contacted
- Mr. Fang: 2x Each - Shipped
- cinema.av: 1x Each - Shipped
- Saiteron: 3x Module (B) - Shipped
- csboling: 1x Module (B) - Shipped
- AnalogMonster: 1x Module (B) - Shipped
- allthesixes666: 2x Module (B) - Shipped
- DesertMuseum: 2x Module (B) Built - Shipped
- MayToast: 1x (A), 1x (B) Built - Shipped
