So what are Ramps? Some kind of waveform, of course, but just what kind? I haven’t figured this out yet.
And once they are broken into horizontal and vertical components, how do we bring them back together into one signal?
rising saw, falling saw, triangle, inverted triangle
both for Horizontal and Vertical.
The shapes are not ‘broken into components’.
Functions and uses:
mixer / keying and wipes (combine several ramps to make interesting shapes)
modulations
orientation tools for several fancy new LZX modules
Ramps are kind of a broad category which I would say are maybe defined by being derived from the sync signal, as opposed to oscillators which are free-running unless they have their phase synced. Often this means that ramps are stationary on the screen, while oscillators can scroll when tuned to frequencies that are not exact multiples of the sync rate.
For instance, the most basic kind of ramp waveform is probably a rising horizontal ramp: it is 0V at the left edge of the screen, 1V at the right edge of the screen, and linearly ramps from 0V to 1V across each scanline, so you get a linear gradient from black to white horizontally.
Consider this excerpt from the Cadet IV schematic:
There’s a fair bit going on here, but we can break it down, going from left to right (like a ramp
The Visual Cortex ramp generator I would guess starts with something similar to the Cadet circuit above, but then passes these linear ramps through more mirroring and waveshaping circuits to give a range of triangles, diamonds, curved shapes, etc. Two of the outputs on the VC ramp generator give a hint to one way to recombine ramps into a pattern that changes both vertically and horizontally across the screen: the “H + V” and “H - V” outputs are the sum and difference of the “H” and “V” signals. You can try mixers, faders, keyers and anything else with 2 or more inputs to build different shapes out of simple ramps, and you can use them as modulation sources, keyer inputs (e.g. for generating wipes), or anything else you wanna try plugging em into. Ramps are also useful for defining coordinate axes for other applications such as shape manipulation or vector rescanning (such as with Navigator and Shapechanger), as well as lots of things I’m not thinking of or that you may yet discover.
Ah, that’s it! So waveforms derived from the sync signal. That makes sense. I looked at the output on my O’Tool and it looks like sawtooth waves. I had not tried to mix H and V ramps in a mixer before but I did so with a Doepfer A-138a and it worked. So that’s how I can combine the signals from the Shapeshifter and Navigator! Very cool to have learned this.
use a voltage controlled mixer or a video VCA to get even more shapes!
Use a keyer (hardkey or softkey) with ramps for ‘hard edged shapes’ or ‘soft edges’ - filled shapes
