That’s either a problem with the z signal, or theres a nonlinearity in the ramp. Put your score in to normal mode and view just the ramp in the scope. If it’s just a normal ramp it’s something up with z. Does the blank area scroll or is it stable
You can’t have a hole in an oscilloscope trace, but it can move very quickly from one value to another, like a square wave, although hard to see its still a solid line. So if there appears to be a hole is withe because the signal jumps very quickly from one value to another or because the z is going down to a low value at that part
