Issue with shapechanger
Hello,
I just received my shapechanger. I dont know if i m doing something wrong with it or if i have an issue with it.
Using navigator shapechanger combo i m not able to create a shape and play with as i should do.
So to check the SC i ve pluged directly the H and V ramp from VC. Here the result :
Here the SC setup
Here the VC setup
if someone can help me…
thx
denis
Thank you.
I ve tried. always the same result a screen splited with a white side and a black side.
No shape…
yes of course !
only the navigator. shapechanger doesn t have rca sync
you will need to play with the mirrors to get it working and do 2d quadrilateral shapes, it will take you time to understand all the options shapechanger has.
Try this patch, check all switches are the same
Does the shape show correctly with ramps plugged into shapechanger only?
Hey tanks. you re right, need time to understand the beast. mirror switches solved all my questions.
thanx
Yep, both mirror switches up! The user reference card contains the “home position” in an illustration in case you get stuck.
