Diver flickering
Hi everyone. We’ve been doing some thorough lab testing with Diver, and are in the midst of confirming some fixes. So far, we track the compatibility issues down to Memory Palace and Cadet I when either are used as the master sync sources.
Once we find a fix, it will either be firmware upgrade (ideal!) or we’ll ask to recall your Memory Palace for a warranty fix that involves some hardware changes. Or there will be a small adapter PCB that solves the issue that we can ship you.
For now I would recommend you try a chain with an external video source as your sync master. For example:
Memory Palace
External Video -> Diver Loop In
Diver Loop Thru -> Memory Palace Loop In (Memory Palace in External Sync mode.)
Cadet I
Diver Loop Thru -> Cadet I Sync/Video In
If you can try this, please let us know how it goes. In the meantime, we’ll be working on a more permanent fix. We’re just drowned in work getting TBC2 ready at the moment. Most of the rest of the year is attention on the Orion modules after that job is done.
