Angles sync issue
Hi all,
Back with another noob question. I recently acquired an LZX system roughly equivalent to the Double Vision 168, with some Syntonie thrown in as well. Having a lot of fun so far, even if the learning process is a bit slow. Any good resources out there for beginners? Anyway, my main question is about what i believe is a sync issue with my Angles module (i’m not sure i 100% understand sync, so bear with me). Here’s what i’m experiencing - the outputs that create strictly horizontal gradients across the screen (2nd and 4th columns) work as i imagine they are supposed to, and in the manner shown in the videos I’ve seen. However, any other output causes the image to scroll from left to right on the screen. I have a Vidiot and this is very much like what happens when you turn one of the sync switches off, so that’s why i assume sync is the issue. i guess i’m confused as to why sync would work horizontally but not vertically (or is it the other way around)? I’ve checked the connections and everything seems to be good. The sync signal flow is ESG3 > DWO3 > DSG3 > Scrolls > Angles. Everything else in the chain, works fine (i think). i don’t currently have the out from Angles going anywhere, as I don’t believe I have any other modules that require sync. I’ve tried replacing the RCA cable between Scrolls and Angles, so i know it isn’t a bad cable. There are two power supply modules, could that be an issue? Anyway, any advice would be appreciated. Apologies for the long post, I just wanted to include as much info as possible. Thanks in advance.
Matt
Hello, Matt.
Congrats on the new system. It’s good to hear you are enjoying it so far.
I have a couple of questions that may illuminate the issue you are having. How is the system powered and which modules are sharing the supply?
Have you tried connecting Angles sync directly from ESG3, and skipping the other modules? It is always a good idea to test the problem module in isolation.
Greetings again,
so ive been busy, but i was finally able to resolve the problem. the thing is, im not sure why exactly this fix worked, so i thought i’d post this here in hopes of finding some clarification, and in case anyone else encounters this in the future. i did indeed try going directly from ESG3 to Angles and it worked as expected. i messed around with some other combinations, but usually ended up with the same issue in the end. i also messed with the power enough to rule that out. finally, it turned out that the issue was the order of the sync. specifically, Scrolls has to be last in the sync chain. as long as Scrolls is last, everything, including Scrolls itself, works as expected. apologies if this is obvious to the veterans, but why would that be? is sync flow a known or obvious thing and i just missed that part? if so, would someone mind running down the basics? anyway, everything’s working now and i’m having a lot of fun. just thought i’d include this follow up in case any other newbies run into something similar. thanks for the help,
Matt
Thank you or the update. It sounds like the sync output on Scrolls is not working correctly. You can test this with a simplified sync chain of ESG3 → Scrolls → Angles. If Angles is not syncing in that test, then the issue is that Scrolls is not passing sync. If that is indeed the case, could you send a message to support@lzxindustries.net to arrange an RMA?
Did you have any luck pinpointing the issue?
