8hp Ramps Adaptation
I would be fine losing a sawtooth output to gain the multiplier input
very much looking forward to this
as of to loose the inv saw on the panel, you could also add a pad on the pcb, for mod possibilities.
I’m for putting pin locations on the PCB for the deprecated features (sawtooth?) and let users build an expander if needed. Also fine with 14PIN sync
I’ve been busy working on all sorts of other things, but I haven’t forgotten about this. Here’s a mockup made from a stack of cadets that I’m going to play with for a while and think about. It’s a pile of a C4 and two C10s with some other doodads tacked on. The controls are global amplitude, multiply, and bias. The I/O jacks are voltage control for the multiplier bias (not a stock feature of the C10), multiply out (morph between triangle and circle), ramp out, and triangle out.
That’s bananas. :smile:
Hey @JonasBers :wave:t3:
I stumbled across your thread and have just read through it. I’m really curious to know how your 8HP Ramps/Multipler project has come along since you last posted. Thanks for any info :+1:t3:
