Vidiot Power Supply?
I lost my Vidiot power supply, and I can’t find any documentation on the power connector size.
I know it takes a 5v DC 1.2A, but what size is the barrel / tip?
Also what is the polarity?
Lars recommended to just use one of these.
this is how i power mine…
Thanks for the reply Spike.
So… that usb cable looks to be 5.5mm OD /2.1mm ID, center is positive.
Is that same cable you use? I don’t want to damage it with the wrong polarity.
same one i bought and use.
Ok thank you, that is very helpful!
This is the one that shipped with Vidiot:
https://www.digikey.com/en/products/detail/cui-inc/SMI6B-5-4-P5R/10264712
Thank you, that’s perfect!
