I am using the v.19 firmware. Have not tried out the new beta yet
The beta should solve the AUX freeze issue.
Can some patch notes be added about the beta firmware? Curious what other fixes/changes it contains. Thank you.
Would also be interested in your opinion on whether or not it’s as stable as V19 for gigging!
It’s just an update for V19 that fixes a number of the bugs. I find it more stable in general.
Probably a low priority bug, but in V2.0.1 if the orange button is pressed while in the AUX submenu the menu seems to freeze.
I have not experienced that in V2.0.1
When utilizing the media loader in warp mode, manipulating the spatial processor seems to introduce significant artifacts. These artifacts don’t seem to be limited to just tiling and rotating, but also appear intermittently during zooming. Following the update, the spatial processor sliders are markedly less responsive to physical inputs. Are there any adjustments that could help this?
Here is a video of the AUX submenu. I tested the same way on both devices.
[In my configuration, Visual Cortex is sending sync to the Memory Palace in the top row of the Vessel, and that Memory Palace is sending sync to the second. Both are powered from the auxiliary port on the back of the device.]
Thank you for confirming the AUX menu bug. I will make sure that isn’t an issue in the upcoming firmware (in which the frame artifact glitch has already been solved).
At the 1:00 timestamp, the zoom on screen doesn’t correlate with the slider movement. Is this related to the frame artifact glitch?
You might want to check the settings for the Zoom slider. Slew and S-curve can be adjusted to your preference.
I encountered this today. Going into Aux submenu locked up MemPal. I recreated it on another MemPal so seems to be a bug.
Does anyone else experience a flicker-ish artifact when using the DVI output from Memory Palace? When I switch to the composite output it goes away.
The DVI output experience will be improved in the next firmware.
I am using v2.0.1. When using the USB SD Card Memory access on Mac, does anyone else find that the their computer will not recognize the Memory Palace drive for a variety of time ranging from a minute to many minutes?
30 seconds to 1:30 on my end but usually closer to 30. Beats pulling it out of the rack and popping the SD card out.
I’m using V19 and a Macbook Pro
I can’t gain access to the SD card through the front port, have I missed something?
I’ve given it at least 5 minutes, still no luck
Some Mac users have no luck connecting to USB. In which case you’ll have to remove the MicroSD and use a card reader. The next firmware should make USB connection easier for Macs.
Did you select USB connection in the System menu after you plugged it in? It is the first option. After you disconnect, restart the module in the system menu to see the changes you made.
If I select the ‘USB Storage’ option in the System menu, it offers me ‘internal’ or ‘SD’ ?
Can I also ask:
i) In the LZX Sensory Translator Patch Tutorial, the trigger is set to multiple booleans/push buttons at once. How is this achieved, please? The trigger menu lets me select one but I can’t see how to select more than that
ii) There’s an option in the System Menu for ‘MIDI Seq’, what does is this for? I’ve searched the forum but can’t seem to pull anything up.
