TBC2/84hp UpDownCross RGB
Hello,
I own an 84hp modular video synthesizer that includes several modules (DWO3x2, Proc, DSG, SMX3, ESG3, and DCDITRO3A), and I want to synchronize my TBC2 module with the rest of the system.
Additionally, I plan to connect my PC using a Blackmagic UpDownCross converter and an SDI-to-analog module to send the signal to the TBC2. However, I’m not sure which RGB cable to use for this connection.
Could you advise me on the cabling and synchronization process?
Thank you!
…i do not understand the question - as in: do you want to synchronize the Blackmagic-devices to the modular or is your question how to include the TBC2 in the modular-synch?
…within the modular the rule - as i understand - is, that the TBC2 should be the first module in the synchronisation chain after the ESG3; so the synch-chain would be ESG3->TBC2->other modules…
Hello Fairplay, here are my questions:
  1. First question: I would like to know how to include the TBC2 module in the synch chaine of my LZX 84hp modular system and understand how the synchronization patch works.
  2. Second question: I have a Blackmagic SDI to Analog module that I want to connect to my TBC2. I am looking to find out which RGB cable to buy to link them
…hey again,
first question: the sync-cable should run from the ESG3-out → to the → TBC2-in → and from there to the other modules…
second question: any (quality) RGB-cable should do - examples (i use) on the (german) amazon-site include (not affiliate links)
…but those are just some examples - in the meantime i have (more than) a drawer full of cables for this purpose…
…there are also cables that do not require the adapter, but the ones i found were very low quality and broke after first or second use (bought 20 of those, have only about 3-4 usable remaining)…
Thank you very much for your answers, I will try that.
