I am trying to wrap my head around Shapechanger’s input possibilities - ramps are meant to be sent to the input but I guess it could be done with a camera input’s luma signal too somehow? Also, I am only dreaming about the other way round: modulating a Shapechanger with a luma signal. If anyone could help out that would be welcome.
You are correct that the input and modulation points on the Shapechanger are capable of receiving and processing any other signal in your LZX system (including the luma signal from a camera’s input). The “somehow” you refer to is as straightforward as patching the luma signal (perhaps output from a Visual Cortex or Cadet III) into either patch point on the Shapechanger. If you try it out, please post results, would be fun to see! Cheers!
