Paper marbling Pack 1 - Google Drive
Here is a pack of several different things
the original cropped scans at full resolution in case you want to do your own image processing on those also 1080,720, NTSC, and PAL version of all 55 images. A text file with the image magik commands used for doing all the batch processing is included. Because I wasn’t consistent in my scanning I couldn’t use a batch crop for the initial cropping.
so the batch rotate and batch resize commands are included there.
This is an old project but it needed to be re done from the originals so that I could get 1080 and 720 versions.
I’m going to get them loaded up on the TBC2.
here are some examples
