Eurorack-accompaniment "Beginner" Visual Synth Setup?
There are many converter options available, with some recommendations on the forum.
Currently the best way to achieve the scan processing look is to use a vector monitor (o-scope or modified Vectrex) or an ILDA laser. Chromagnon will have connections for either, but you will have to lug something with you if you want to use that process live.
