I am planning to start a small modular system using Gen 3 modules to do some of what Vidiot can do, but I don’t need video input. I only need audio input.
I’m thinking of starting out with DWO3, DSG3, and ESG3. I want to be able to use audio input signals, though. How could that be done?
Thanks! It looks like there are a lot of options, which makes sense. Aural Scan sounds amazing. Now I’m wondering how the Vidiot does it, and whether I can just use something like Proc to reduce the voltage.
Another expansive option would be : an audio input module, bandpass filters for extracting bass / mid / high + some envelope followers* to make a very flexible modular setup to finetune incoming audio to control signals
A voltage scaler can scale those signals* to 0-1v
I use a Doepfer a-119 audio input, the Serge Resonant EQ mk2 + a 5x DIY Envelope follower module for this.
I use a Doepfer A119 External Input (envelope follower) and usually a lowpass filter to remove the upper frequency information which can make the signal twitchy when applied to graphics.
It also has a gate out which can be utilized for deriving tempo if you get the gain and threshold just right.
