Hello All,
I created a special demo for you all showing how you can use the blend function in Adobe Illustrator to create simple animation frames for loading into Memory Palace. I hope this can be of use to some of you. This is just the basic process I use, but it can clearly be used in much more complex ways to create dynamic blend, morph and translation effects. Enjoy!
NOTE: The number of artboards in this demo is 21, and it seems that the Illustrator workspace WILL limit the number of artboards to around 21 if arranged in a row as shown (depending on spacing between boards). There can be more if arranged in a column or grid, but you may have to splice multiple blends together between each row of artboards.
