Heya LZX family,
Here be a few projects we’re working on:
DBS-14
A busboard w/ 14 x 2.1mm DC Barrel Jacks for feeding those various Gen3 modules +12V power. Good for 8A [EDIT: 5A] (each individual connector is rated for 2.5A). Has some basic noise suppression bits on board for smoothing ripple & rejecting common mode noise - a big Wurth Common Mode Filter, Murata BNX-16, and a few big OS-Con caps. Reverse power protection, yeah.
Measures ~ 83mm x 45mm x 30mm. Same bolt/screw spacing as Capsule for the pair of mounting screws.
Has a little 2 port terminal block for direct wiring to whatever jack you may want to feed it from - or wiring it to our INX-1 Input panel.
We’re planning to offer these as a power option alongside an upgraded 14 connector Capsule variant in our cases. If you want to get an idea what our case system is like see Scopic Webstore
INX-1
4hp DC Input & Sync Pass-through module
SCA-5
2hp or 4hp (your choice) 5V to 1V scaler
I’m going to redo the compo board because I figured out a better layout 1hr after ordering ![]()
Otherwise good to go.
Imagine we’ll do a little run of each, pending interest
