This thread should serve as a general resource for the brownshoesonly Video Grip.
Module info:
14HP
FORMAT: performance, mixing, multiplying, wavefolding, routing, quad, pattern generation
PATCHES: Quad Pan, Vector Mix, Manual CV Control, Generative/Autonomous modes
VERSIONs: can be ordered with springs intact for an effect based version. Great for Vca chains and Orion allowin temporary performance Wet effect. (springs can always be removed by user. replacing springs is also doable but a bit more difficult)
USER ADJUSTMENTS: spring tension. PLUS Y-tension or detent regardless of springs (mostly for angled or vertical cases)
(documentation to be updated on this first post along with a concurrent FAQ from the thread below.)
