yeah , that is a good idea.
I’ll make a jumper for it, so that if you do not use this option, the stage is grounded.
(like in the schematic above )
Maybe I’ll add a “experimentation area”.
Question: Shall I leave out the resistors + capacitor, like in stage 1?
Maybe I can fit them, but if it is an experimental area, It might be useful not to have a predetermined use.
new stuff. 2nd c-sync bus for alternative connectors. / extra output.
When not used, there is an easy grounding option next to the LM6172. so a bypass = 2 jumpers
It all fits, so that is cool! The pcb has a less funky shape, oh well
And I’ve added one extra sync header. so there are nine in total!
Last check before I send it to China!
Okay, we tested the busboard with LZX modules this afternoon. Thanks Jim!
RCA sync out --> works (tested with Prismatic Ray)
VC 14pin sync out to busboard -> works
busboard RCA out to RCA input 2nd sync gen --> works
So I declare it functional!
I’ll make a buildguide & BOM.
The pcb’s / kits / build units will be offered for sale.
I’ll ask Lars if it is ok to do it from this forum. I have an Etsy store as well.
