I was thinking of an expanded update for the matrix mixer. 3x3 attenuverted pots + a set of overall gain control for each channel + gain amount switches
So you wouldn’t need an inverted section, because each channel can be inverted or not.
I hope the middle point or zero is easy to set though. the overall gain might help with that a little.
What was it that was said about chaining inputs?
more on topic: the CMIX is ordered.
8HP panel
3 normal ins with pots
3 inverted ins with pots
2 outs
Some mods are possible for keying effects (like the Matrix mixer), but I have added no
dedicated MODpoints as the pcb is tightly packed. so (there is) no space left!
(on the pcb I mean, not space in general)
thanks, that is what I meant. edited the sentence for ultra clarity!
The pcb’s are in! now to test … soldering iron engaged
and it works!
I’ll setup an order thread !
Fantastic news👏🏼
Good work @reverselandfill
Bom and Schematic are here for download:
| CMIX BOM v1 2020 |
| Resistors |
value |
details |
amount |
| r1, r2, r3, r4, r27, r30 |
100k |
6 |
| r5, r6, r7, r8, r14, r24, r26, r29 |
499r |
8 |
| r9, r10, r11, r12, r13, r15 |
1k |
6 |
| r17, r18, r19, r20, r21, r22, r23, r28, r31 |
10k |
9 |
| Ferrite beads |
| f1, f2 |
2 |
| Diodes |
| d1, d2 |
1n4001 |
reverse power protection |
2 |
| Capacitors |
| c1, c2 |
10uF |
>16v electrolythic |
2 |
| c3, c4, c5, c6, c7, c8, c9, c10 |
100nF |
Ceramic, 2.5mm |
8 |
| IC |
| u1, u2, u3, u4 |
8pin socket |
optional |
4 |
| u1, u2, u3, u4 |
LM6172 |
4 |
| Power |
| SV1 |
10pin |
shrouded header |
1 |
| power cable |
10pin to 16pin |
keyed headers |
1 |
| Hardware |
| Pots |
b10k |
vertical 9mm Alpha |
6 |
| Jacks |
Thonkiconn |
8 |
| Knobs |
6 |
| M3 screws |
for panel mounting |
4 |
Build tips
Use this order for placing the components:
- IC sockets
- 100nF caps (the kit uses vertical mounted types)
- resistors
- diodes
- ferrite beads
- power header
- polarised 10uF caps
- pots & jacks
Just got my pcb set yesterday, many thanks @reverselandfill!
Here is a quick test, shapes are generated using CMIX (H ramp, V ramp, 3x Cadet VCO, 1x Castle VCO), then sent to VU002 for doubling, the 4 outputs goes to Matrix Mixer, then to RGB encoder, and further processed in composite using CBV002.
Resistor placements to help you build the CMIX while I continue to write the build manual
see also here
1k
10k
100k
499r
