Hello,
how can i shift the phase of a waveform from prismatic ray ?
Navigator does that ?
thx
You can do it by delaying the sync pulse. One way is to use a key output (generated from horizontal or vertical ramp) and patch this into the sync input on Prismatic Ray. Now if you modulate key threshold, you will change the phase of the VCO. Another way is to process with Shapechanger, which can modulate phase in a discontinuous way (but it looks pretty.)
it works. thx. it s usefull for lissajous curve with cyclop
If you have Mapper, try feeding HUE with your VCO, but then take the U & V outputs to patch to X & Y of your Cyclops. Now you can use Saturation/Brightness as modulation inputs. This should allow some phase displacement too.
