Hi, super dumb question, but maybe someone else is baffled by the same issue - how do you START a playlist? I have two files, both play fine. Built my two-file playlist, and assumed it would switch over to playing it when I exited the playlist editor - but it is only playing the first file. Is there an extra step to point it to the playlist?
Youâll need to make a playlist that includes jumps from one file to the next. The easiest way is to go to the Playlist Options menu and âAutomatically create playlistâ this will add all your files and the appropriate commands for a looping playlist.
