The intention is that this is both the system’s quad active mult and it’s quad amplifier/attenuator (with presets). Think of it as straddling both functions (which are essential, core functionality for a modular system). We found this worked well in patching context on our Bridge module – usually if you’re level translating an external signal, you want a mult at the same place (to distribute through your patch.) Also, many cases where you are using an active mult – preset gain modes come in quite handy (like overdriving a video source to create a distributed soft key.)
The 2-in-1 nature here serves another purpose: a voltage scaler may not be used in all patches, but a dedicated mult is almost always going to be in use. So this is a currency in our design guidelines – we want every HP worth of module to be useful in as many different patches as possible, even when they play different roles. It’s a big ask, to pay a lot for a module with some preset voltage scalers on it, so we try to overlap things in a way where the module can pay it’s rent in multiple ways. That’s my thought process in any case.
Unless arranged in rows instead of columns, the inclusion of rotary switches would require that this be a three channel (instead of four) module. You can see the formula I’ve developed for Gen3 ergonomics here so you can see the constraints more specifically (this example shows SMX3 – 9 knobs, 12 jacks):
two position toggle switch for multiply or divide (no need for neutral setting if no mult function)
Agreed on this point if we excluded a mult – however it’s worth pointing out that a 3-position toggle is essentially “free.” That is, no extra panel space and negligible extra parts cost to go 2 instead of 3. Some controls are of course, binary by their nature and a third position could be confusing.
A three position “bipolar to unipolar / bypass / unipolar to bipolar” toggle is something I had on an earlier mockup. I think that’s a good idea, especially if we drop some mults.
Another alternative to mult outs are complementary outs (positive and negative.) For example, we could drop 2 outs in favor of this. This would be a similar layout then, to DSG3, if combined with a polarity mode (12x toggles, 12x jacks)
Dropping the mult outputs – adding the complementary outputs – we could have a third range setting on the amp level. For example, 2X, 5X and 10X. This could work, but then we need a separate module as the go-to active mult (not really an issue, but if you are trying to make a small system it makes it more difficult, if you need both functions.)
These are just designer musings – not necessarily a defense of the existing configuration. This is actually a great case where soliciting user feedback before we commit to a design is a good idea.
