Using a LZX Sync generator to control videocamera
Hello, I have an old Black and White Sony AVC 4200 camera and would like to control it using a LZX sync generator and I am hoping for some guidance.
The camera has the following Sync inputs:
  1. “SYNC CLIP” input
  2. “Horiontal Drive” input, which is a Horizontal gate
  3. “Vertical Drive” input, which is a Vertical gate.
These can be input either on a 10 pin or 6 pin DIN.
The camera scans at 525 lines/frame, 30 frames/second with positive interlace. I believe this is 480i NTSC but I am not sure.
I have two main questions:
a) what is the SYNC CLIP, or what is it likely to be?
b) Which LZX module would I be able to use to modify the vertical and horizontal frequencies? I am hoping to drive the camera at 59.994Hz (instead of the default 60Hz) so that I can actually use the camera’s video in an analog-to-digital converter for further processing. But I would also like to experiment with driving the camera at different scanning rates.
Thanks!
Hello & welcome to the community forum @mgualt :slight_smile:
I can’t answer you first question about Sync Clip but surely to your second question, the best answer I can give is the Visual Cortex.
Here’s some possibly relevant info from the Visual Cortex’s Technical Manual pdf as found here:
SYNC GENERATOR
The Sync Generator section is a broadcast specification video sync generator which can operate in NTSC/480i or PAL/576i timing formats. It can provide the master timing reference for an entire video synthesizer system, and its timing may be synchronized to an external video source.
Frontpanel:
A. Sync Format LED Indicators. Indicates NTSC or PAL mode.
B. Sync Lock Status LED Indicator. Green when locked to external sync, red when external sync is detected but no lock can be achieved.
C. Horizontal sync output jack. A pulse at the beginning of each video scanline.
D. Vertical sync output jack. A pulse at the beginning of each video field.
E. Frame rate clock output jack. A gate is turned on at the beginning of each odd field (the start of a new frame), and off at the beginning of each even field.
F. Dither pattern output. A dithered pixel texture for shading video objects. The spatial geometry of the texture is influenced by the selected Ramp Generator modes.
