Hi guys I have few possibilities for the mountain switch, see picture below. Which one do you suggest?
On the board there are 2 holes for the front legs and 4 rows of three holes. Are these 4 rows all comparable, e.g. connected, so I can use whichever I want?
Another question can I substitute the multilayer ceramic caps with some monolith ceramic caps from Tayda? What about ceramic disk? Are they comparable?
for the 1N4001 I have 1N4001T rectifier and G half rectifier are they both ok?
Thanks
the big 2 holes near the edge are for holding the switch.
the 2x3 placements are for 2 types of switches:
- a small sideways mounted switch that uses those holding pins
- a bigger one, that uses wire connections)
you need a DPDT type switch, which has 6 pins.
1N4001T looks fine.
what caps are you looking to replace? (what values / types?)
for the 100nF caps: these can be replaced with common ceramic or whatever you can find)
Continuing the discussion from Mountain SWITCH possibilities, Caps Diodes:
Great thanks so much all clear!!
