Hey, im working with a visuals designer on a big show coming up in a few days. We ran a lot of his footage through my synth system, captured the pal stream on my hackingtosh, and he is now working on rescanning it all on a CRT, using a sony a7s3 camera, but he has trouble finding a setting that looks good in the camera. End result will go to a 10x6 screen on a festival stage.
Any recommandations from similar or roughly similar cameras most welcome!
It a bit urgent. Im not there myself since im on another production.
Thanks!
Thanks, saw the post, but didnt have time for watching videos (while building and programming LED screens and all AV infrastructure on another festival stage.) The post is mostly about capturing stills, but the video links might have something for next time😀
I heard back from the visuals designer, that he managed to get som decent rescans, but with imperfections. So he opted to use the captures for some segments of the show and the rescans for other. Have not seen any of it. Promise ill send a video of some of the results on screen…when im on the other side…
Thanks!
/Lau
Sounds thin I know - However, iPhone cameras are really great at capturing crt screens. I’m not sure if the resolution will be high enough for a larger format screen projection.
I found that changing the settings on a video camera to night time mode helped with crt capture as well.
To piggy back off this - I use the Filmic Pro app which lets you adjust lots of bits and bobs, great app
Hey All, realized I never posted any follow up videos as promised.
The concert was a big sucess, with crowds cuing up many hours before the show around the festival stage, that had a capacity for only 17k crowd, for the most anticipated concert on the whole festival selling 100k tickets. So i ended up seeing “my own show”, form right outside the tent without my friends that couldnt get nowhere near the tent.
Had expected somebody posting some better quality videos, but the recordings made from the production was not shared in any fuller form. So will have to make do with crowd recordings, and a little better one from an iphone in FOH.
Here you can see my MX50 color splash universe solo, going directly into Vidiot audio envelope follower black and white with dancing skeletons…
https://youtu.be/df8aKNFOWZk?si=WTRBmbyqHocHqXzJ
Here you can see a little rescanning action going to the big screen:
https://youtu.be/o0zYSYiwy2o?si=lprjC_hoR7Md_qFD&t=759
Hope u like it, and thanks for the help in a tight spot
Best. Lau
