Hi all!
DigitalVisualMixer is a visual mixer for musicians, DJs, VJs, streamers and anyone curious about generative art. It uses Hydra, a creative-coding language where a single line like osc().kaleid() becomes a moving kaleidoscope. The app makes it approachable for beginners and fast for experts.
Start with zero knowledge. Right-click in the editor to insert ready-made functions, hover them to see their parameters, and open the built-in Guide with F1. Every change shows up first in a private preview.
Build a set. Save each visual in its own channel. Search, reorder by drag and drop, and send channels live with cut, crossfade or add transitions, all from the keyboard.
Perform it. Turn any number into a live variable and move it with a slider, a gamepad, a MIDI controller or the keyboard. The visual changes smoothly, without restarting. Perform view gives you big pads for channels and presets, so you can play a full show without touching code.
Show it anywhere. The live output runs in a separate window, so you keep working while the audience watches. It’s also shared on your local network: open it on a projector, a second PC, a tablet or a phone.
No setup. A single file, no installation. Windows , linux and macOS.
repository
releases
