Does anyone have any suggestions/techniques/gear they use to create more composite (or Svideo/YPbPr outputs from the Cortex, now that the Cadet composite output module is no more?
Will be for sync generation for cameras and also for extra displays
I’ve used the Bridge and passive mults, but am thinking more of something outside of the rack
Saiteron, [Teleos Modular] has a visible signals composite mult for sale on reverb. Maybe contact him through this message board. That’s probably the easiest method for sending all those genlock signals.
Do you want the same output duplicated, or different output images?
If just same output duplicated there are many distribution amps, both in a rack and external. Syntonie has one, visible signals, fox, etc
There are of course many UK distributers for Kramer, Aja, etc. This TV-One 1->8 amp looks like great value. You might find one on ebay for less. RCA<->BNC cables are also easily found.
I’d use a similar device if I didn’t have a pair of TVI modules. (These were Visionary series, so discontinued.) So I already have 6 dedicated sync outputs and 2 composite outputs on my VC that can function as sync. If I wanted to, I could chain the sync on my cams, but I’ve never bothered. Unfortunately, not all CCTV cameras support this option.
That’s one of the reasons these distribution amps exist. So many devices still use sync.
It depends on how many sync signals you want to send, I guess. You might not want so many cables connected directly to your modular. A single sync output to an out-of-the-way distribution amp could be tidier. There are also import/shipping issues to consider. DIY would help with that, but for some of us there’s only the assembled option.
Hi @Tundra_Tides
I’ve got a nearly complete complete Visible Signals (VSig) Video Distributor here in Berlin on workbench. They final components arrived yesterday so I’ll be able to finish it when I get home in about 4 or 5 hours. I’ll take some photos later.
I’ve recently sold stuff to a LZX user in the UK (via the Facebook group page), postage took about a week, no issues with customs thankfully
Please write to me on here if this sounds promising to you
