Hi there I have an issue compiling the Chromagnon Simulator:
I’m on Monterey, this is my log, any help? I see the dylibs as aliases maybe that’s the problem?
Thanks
Translated Report (Full Report Below)
Process: simulator-chromagnon [4442]
Path: /Applications/simulator-chromagnon.app/Contents/MacOS/simulator-chromagnon
Identifier: com.lzxindustries.chromagnon
Version: 0.1.0 (0.1.0)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2026-01-13 10:51:37.9016 +0100
OS Version: macOS 12.7.4 (21H1123)
Report Version: 12
Bridge OS Version: 9.5 (22P5072)
Anonymous UUID: 0F5713BC-BFEB-C986-BD3E-AB538FB619D1
Time Awake Since Boot: 5100 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: ‘@rpath/libsfml-graphics.2.6.dylib’
Referenced from: ‘/Applications/simulator-chromagnon.app/Contents/MacOS/simulator-chromagnon’
Reason: tried: ‘’ (no such file), ‘’ (no such file), ‘’ (no such file), ‘’ (no such file)
(terminated at launch; ignore backtrace)
Thread 0 Crashed:
0 dyld 0x1184a79a2 __abort_with_payload + 10
1 dyld 0x1184bdab2 abort_with_payload_wrapper_internal + 80
2 dyld 0x1184bdae4 abort_with_payload + 9
3 dyld 0x11846b699 dyld4::halt(char const*) + 615
4 dyld 0x1184675b5 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 3995
5 dyld 0x1184664e4 start + 388
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000002000209 rbx: 0x0000000000000000 rcx: 0x00007ff7b1575638 rdx: 0x00007ff7b1575aa0
rdi: 0x0000000000000006 rsi: 0x0000000000000001 rbp: 0x00007ff7b1575680 rsp: 0x00007ff7b1575638
r8: 0x00007ff7b15756a0 r9: 0x0000000000000000 r10: 0x0000000000000081 r11: 0x0000000000000246
r12: 0x0000000000000081 r13: 0x00007ff7b1575aa0 r14: 0x0000000000000001 r15: 0x0000000000000006
rip: 0x00000001184a79a2 rfl: 0x0000000000000246 cr2: 0x0000000000000000
Logical CPU: 0
Error Code: 0x02000209
Trap Number: 133
Binary Images:
0x118461000 - 0x1184ccfff dyld (*) <430a12c9-134a-3904-9d88-c2df933fdf54> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2212K resident=0K(0%) swapped_out_or_unallocated=2212K(100%)
Writable regions: Total=10.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.8M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
STACK GUARD 56.0M 1
Stack 8192K 1
VM_ALLOCATE 12K 3
__DATA 1872K 3
__DATA_CONST 92K 2
__LINKEDIT 516K 3
__TEXT 1708K 2
dyld private memory 1024K 1
TOTAL 69.1M 16
Full Report
{“app_name”:“simulator-chromagnon”,“timestamp”:“2026-01-13 10:51:38.00 +0100”,“app_version”:“0.1.0”,“slice_uuid”:“cb51fcbf-5360-3673-9a66-6d631310d84b”,“build_version”:“0.1.0”,“platform”:1,“bundleID”:“com.lzxindustries.chromagnon”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.7.4 (21H1123)”,“incident_id”:“24B3479C-84F2-4511-9BA4-3C2AA6B358DA”,“name”:“simulator-chromagnon”}
“uptime” : 5100,
“procLaunch” : “2026-01-13 10:51:37.2782 +0100”,
“procRole” : “Background”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro16,2”,
“procStartAbsTime” : 5119512947553,
“coalitionID” : 2593,
“osVersion” : {
“train” : “macOS 12.7.4”,
“build” : “21H1123”,
“releaseType” : “User”
“captureTime” : “2026-01-13 10:51:37.9016 +0100”,
“incident” : “24B3479C-84F2-4511-9BA4-3C2AA6B358DA”,
“bug_type” : “309”,
“pid” : 4442,
“procExitAbsTime” : 5120131926900,
“cpuType” : “X86-64”,
“procName” : “simulator-chromagnon”,
“procPath” : “/Applications/simulator-chromagnon.app/Contents/MacOS/simulator-chromagnon”,
“bundleInfo” : {“CFBundleShortVersionString”:“0.1.0”,“CFBundleVersion”:“0.1.0”,“CFBundleIdentifier”:“com.lzxindustries.chromagnon”},
“storeInfo” : {“deviceIdentifierForVendor”:“77B20982-CA31-577A-B2C7-D7057726BF39”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.lzxindustries.chromagnon”,
“crashReporterKey” : “0F5713BC-BFEB-C986-BD3E-AB538FB619D1”,
“bridgeVersion” : {“build”:“22P5072”,“train”:“9.5”},
“sip” : “enabled”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000000, 0x0000000000000000”,“rawCodes”:[0,0],“type”:“EXC_CRASH”,“signal”:“SIGABRT”},
“termination” : {“code”:1,“flags”:518,“namespace”:“DYLD”,“indicator”:“Library missing”,“details”:[“(terminated at launch; ignore backtrace)”],“reasons”:[“Library not loaded: ‘@rpath/libsfml-graphics.2.6.dylib’”,“Referenced from: ‘/Applications/simulator-chromagnon.app/Contents/MacOS/simulator-chromagnon’”,“Reason: tried: ‘’ (no such file), ‘’ (no such file), ‘’ (no such file), ‘’ (no such file)”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:69749,“threadState”:{“r13”:{“value”:140701808941728},“rax”:{“value”:33554953},“rflags”:{“value”:582},“cpu”:{“value”:0},“r14”:{“value”:1},“rsi”:{“value”:1},“r8”:{“value”:140701808940704},“cr2”:{“value”:0},“rdx”:{“value”:140701808941728},“r10”:{“value”:129},“r9”:{“value”:0},“r15”:{“value”:6},“rbx”:{“value”:0},“trap”:{“value”:133},“err”:{“value”:33554953},“r11”:{“value”:582},“rip”:{“value”:4702501282,“matchesCrashFrame”:1},“rbp”:{“value”:140701808940672},“rsp”:{“value”:140701808940600},“r12”:{“value”:129},“rcx”:{“value”:140701808940600},“flavor”:“x86_THREAD_STATE”,“rdi”:{“value”:6}},“frames”:[{“imageOffset”:289186,“symbol”:“__abort_with_payload”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:379570,“symbol”:“abort_with_payload_wrapper_internal”,“symbolLocation”:80,“imageIndex”:0},{“imageOffset”:379620,“symbol”:“abort_with_payload”,“symbolLocation”:9,“imageIndex”:0},{“imageOffset”:42649,“symbol”:“dyld4::halt(char const*)”,“symbolLocation”:615,“imageIndex”:0},{“imageOffset”:26037,“symbol”:“dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)”,“symbolLocation”:3995,“imageIndex”:0},{“imageOffset”:21732,“symbol”:“start”,“symbolLocation”:388,“imageIndex”:0}]}],
“usedImages” : [
“source” : “P”,
“arch” : “x86_64”,
“base” : 4702212096,
“size” : 442368,
“uuid” : “430a12c9-134a-3904-9d88-c2df933fdf54”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“sharedCache” : {
“base” : 140703442804736,
“size” : 19331678208,
“uuid” : “49e18b84-2cd0-3c1e-9270-0e198c2fdf68”
“vmSummary” : “ReadOnly portion of Libraries: Total=2212K resident=0K(0%) swapped_out_or_unallocated=2212K(100%)\nWritable regions: Total=10.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.8M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8192K 1 \nVM_ALLOCATE 12K 3 \n__DATA 1872K 3 \n__DATA_CONST 92K 2 \n__LINKEDIT 516K 3 \n__TEXT 1708K 2 \ndyld private memory 1024K 1 \n=========== ======= ======= \nTOTAL 69.1M 16 \n”,
“legacyInfo” : {
“threadTriggered” : {
“trialInfo” : {
“rollouts” : [
“rolloutId” : “6297d96be2c9387df974efa4”,
“factorPackIds” : {
"deploymentId" : 240000032
"rolloutId" : "5f72dc58705eff005a46b3a9",
"factorPackIds" : {
"deploymentId" : 240000015
“experiments” : [
Model: MacBookPro16,2, BootROM 2075.120.2.0.0 (iBridge: 22.16.15072.0.0,0), 4 processors, Quad-Core Intel Core i5, 2 GHz, 16 GB, SMC
Graphics: Intel Iris Plus Graphics, Intel Iris Plus Graphics, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, LPDDR4X, 3733 MHz, Samsung, K4UBE3D4AA-MGCL
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, LPDDR4X, 3733 MHz, Samsung, K4UBE3D4AA-MGCL
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 18:02:56 version 9.30.464.0.32.5.76 FWID 01-c081cfed
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: AX88179A, Ethernet, en11
Network Service: USB 10/100 LAN, Ethernet, en12
Network Service: Broadcom NetXtreme Gigabit Ethernet Controller, Ethernet, en13
Network Service: Belkin USB-C LAN, Ethernet, en14
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: T2Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 86.0
