Anything is possible if you believe in yourself. I am believing in these FKG3s and exploring the possibilities of foreground and background pass through while luma keying. Possibilities that do not conform to background or foreground pass through have been marked with question marks, because good questions are the secret to the universe.
Visual Cortex Ramp and Key Reference:
- VC H+V Ramp > VC Ch. B > OUT
- VC H+V Ramp > VC Key+ > OUT
(VC Crossfader Sweep)
- VC H+V Ramp > VC Key- > OUT
The following was completed with FKG3, SN#0194
- VC Input Decoder > FKG3 > VC Ch. A > OUT
(FKG3 FG/Luma/Threshold 0/Softness 0 = FG PASS)
(FKG3 Negative/FG/Luma/Threshold 0/Softness 0 = BG PASS)
Key:
- VC H+V Ramp > FKG3 Key > OUT
(FKG3 Key/Luma/Threshold 0/Softness 0 = ???)
From configuration above:
- Softness 0, Threshold 0-100 Sweep,
- Threshold 0, Softness 0-100 Sweep,
(FKG3 Key/Luma/Threshold 100/Softness 0 = BG PASS)
(FKG3 Key/Luma/Threshold 0/Softness 100 = BG PASS)
Negative/Key:
(FKG3 Negative/Key/Luma/Threshold 0/Softness 0 = ???)
(FKG3 Negative/Key/Luma/Threshold 100/Softness 0 = FG PASS)
(FKG3 Negative/Key/Luma/Threshold 0/Softness 100 = ???)
The following was completed with FKG3, SN#0080
Key:
(FKG3 Key/Luma/Threshold 0/Softness 100 = ???)
Negative Key:
Following tests completed with FKG3, SN#0079
(FKG3 FG/Luma/Threshold 0/Softness 0 = ???)
(FKG3 Negative/FG/Luma/Threshold 0/Softness 0 = ???)
Key:
Negative/Key:
TLDR:
The following reference presents the output of three FKG3s. The output of each FKG3 is arranged by column. Each line represents a configuration that approximates background or foreground pass through. You may notice that the output from identical configurations of different modules is different.
