When we first started using our 2018+ Prismatic Rays (RCA sync), we did not use the rear sync connections. Every patch relied on sync via the front panel inputs, and worked like a charm – all ranges had beautifully stable images. A few weeks later, we chained the rear panel RCA sync connection from the Visual Cortex out, through the Liquid TV, through two Prismatic Rays, and out to the Vessel case connector (with nothing plugged in outside the case). Range 1, 2, and 4 still work well, just like before.
Unfortunately, from that moment forward, both of our Prismatic Rays have displayed some instability in Range 3 with Vertical sync, producing a vertically pulsating displacement in our horizontal bars, spanning about 1-4 scanlines when observed with high gain. With patience and the Fine Freq. knob, a stable spot can be found – but any adjustment to frequency requires that same return to the Fine control.
Even when the PR rear panel sync is overridden with front panel Vertical Sync directly from the Cortex front panel, the twitchiness is still there. I just verified that removing the Vessel case output and/or Liquid TV from the sync daisy-chain makes no difference. And with the rear sync disconnected from the Visual Cortex, the front panel Cortex->PR sync still produces a stable V-sync, as it did initially.
The vertical displacement is most noticeable on our CRT display, similarly noticeable in the Liquid TV, and less noticeable in the Intensity Shuttle’s capture.
What’s the best way to go forward troubleshooting and solving this issue?
Thanks for your time!
48HV
