LZX Gen3 Primer & FAQ: The Future With Chromagnon & LZX Modular
We won’t officially be supporting any daisy chain cables just because it’s a potential liability. You do not want to have loose/disconnected hanging DC barrels crammed behind the modules in your rack after installation – that could short against parts or connectors on the rear circuit boards and cause issues. So if you have unused connectors on your daisy chain cable, be sure you cap them with an insulated barrier or insulate them with electrical tape, etc before power up.
Also, with daisy chaining it would be possible to connect more modules than your power barrel/brick can support. So it puts you in the position of adding up your current ratings. On the LZX DC Distro the connector itself is rated for 5A maximum. So even if you had a 15A brick for example, you wouldn’t want to push 15A of current through the connector.
Also, if you are going to daisy chain you need to ensure you are using a wire gauge thick enough to carry the current. So you’d want to do it in segments, not in one long row. For example a 1 in, 5 out chain cable per row, with each cable going to a DC distro outlet, would be better than several daisy chain cables in series with each other.
TLDR; Daisy chain is okay, but you need to know what you’re doing. If you stick with DC distro or a limited scheme, you don’t have to think about it as much.
I prefer parallel distribution like DC Distro or these kind of supplies, where you have parallel output adapter from the power brick directly:
https://www.amazon.com/Fancy-Buying-100V-240V-Certified-Transformers-Fits/dp/B076HKCRNG/ref=sr_1_2?crid=2UHOUMFRU0SG0&keywords=dc+12v+cctv+power+supply&qid=1642358102&sprefix=dc+12v+cctv+power+supply%2Caps%2C126&sr=8-2
