Is there a suggested max load for the DC Distro with the brick LZX includes with the module?
I think I see 5.8A max output on the brick, so I just wanted to confirm the 0.8A is enough headroom and we can run it up to 5A as suggested on the website product description.
Thanks!
Running it at 5A shouldn’t be a problem. You usually only need to worry about headroom when we’re talking EuroRack power supplies powering modules directly off of +/-12V. The Gen3 modules and Capsule Power all have fancy ripple killing EMI filters on the power inputs (followed by ripple killing LDOs) and should perform well even if input power is quite noisy.
