ESG3 Encoder is our third generation of video synthesis core modules, offering everything you need to convert voltages from your EuroRack synthesizer into HD/SD Component and SD Composite video signals.
Thank you for providing this resource on color balance by vector scope. I am rather asking for whatever protocol HQ may be using to efficiently calibrate ESG3 hardware before shipment. I ask because it was necessary to adjust mine and that adjustment was challenging due to the interaction of gain and offset. A reference of such adjustment from the manufacturer for this module will be a great time saver for LZX and consumer alike. Such a reference is sometimes found in user manuals for products with similar general function. With that in mind this thread seems like the proper place for this inquiry and any forthcoming resources to collect.
Absolutely, once there is time to create a step-by-step guide for user calibration, a link will be posted in this “All About…” thread. In the meantime, color balancing can be performed using the module’s trim pots and the information in the link I shared. However, most image adjustments will be performed using the contrast and brightness knobs on the front panel. They are there to allow the user to tailor the output of ESG3 to the desired aesthetic.
